I've been trying for 3 days now to setup my Auros 1070 eGPU on my 2015 15' with m370x dedicated graphics, but i'm having issues. I've followed the guides below and I haven't had success with either. I have everything needed including the official TB2 >TB3 Apple adapter and an Apple TB2 cable. The issue i'm running into is that the eGPU won't even turn on whenever i connect it or show up in device manager. So my question is has anybody that has the same Macbook as mine gotten this setup to work on Windows 10 currently, and if so do you have the steps you did to make it work? I am going to start over from scratch now but I'm not sure what works and what doesn't.
GUIDES
https://egpu.io/forums/builds/MacBook-pro-retina-mid-2015-aurous-gaming-box-1080/
.UPDATE: So I was able to get everything working in the first guide. refind and the apple_set_os.efi and in device manager, it shows my intergrated graphics, but for some reason i can't get the gaming box to be recognized on my laptop. it doesn't even show up on device manager.
