Hi guys, happy new year! Anyway I wonder if someone can help. I just got a blade 15 advanced (mid 19) with 2080 max q and core x chroma with 2080 ti. I thought it would be straight forward but turned out it’s more complicated then I thought...
I encountered code 43 for the 2080 max q after connecting the blade to the core x chroma - it did appear to be resolved by simply reinstalling the nvidia drivers.
Now my main problem is that when I turn off the blade the core x chroma will go quiet then the fans of the 2080 ti will go full on and the only ways to power the card down is to remove the thunderbolt 3 cable or by the power button of the core x chroma. Bios/drivers on my blade are all up to date. Anyone knows how to resolve this?
.@apepat The Radeon VII is well-known for a similar issue. Which particular model is your RTX 2080 Ti?
It’s a Inno3D 2080 Ti Gaming OC X3. I did a few further testings, it appears that it has nothing to do with my Blade... I plugged it to a usb hub that has a type c while it was connected to nothing (and no power) and the chroma’s PSU would start plus the 3 fans of the card. It would stop again if I powered it down manually or unplugging the type c cable. I removed the card and tried plugging to the hub again and I could hear the PSU turned on. I contacted Razer and they said it should not do this and they would arrange a replacement now - not sure if that’s really the case but guess I can only tell when I try it with another unit.
It’s going to be a long wait I think - won’t get a RMA email until next week apparently and they need to receive the defective unit before sending out a new one so I don’t think I will get a replacement until end of Jan as it takes a week to send it from UK to their Europe warehouse (and vice versa)... Wished I got it from Amazon sigh...
