mac mini 2018 big sur and razer core x egpu will it work for imovie without cras...
mac mini 2018 big sur and razer core x egpu will it work for imovie without crashing?
bladest
(@bladest)
Hi i own mac mini 2018 with big sur i am  planning to speed my imovie editing can u tell me if egpu from razer core x  with amd will it work properly , or not i read for most people imovie crashes when they try to use egpu ? is this fixed or not if its not can u tell me other manufacturer which egpu works best with mac mini?
Kai the Film Geek
(@kai-the-film-geek)
@bladest, I have two Razer Core X with AMD Radeon VIIs with my 2018 Mac mini...and they work great. I don't use iMovie though...Davinci Resolve is my editor of choice.
Mac Mini 2018, 3.2 GHz 6-Core Core i7, 64 GB RAM, dual eGPU Radeon VII 16GB, 2 x Razer Core X, Blackmagic Intensity Pro 4K in Sonnet Echo Express SE-I TB3.
MacBook Pro 2017, 2.9Gh 4-Core Core i7, 16 GB RAM, Radeon Pro 560, 4 GB VRAM
iPad Pro 2018 with Apple Pencil 2
2018 Mac Mini [8th,6C,B] + Radeon VII x2 @ 32Gbps-TB3 (Razer Core X) + macOS 10.15.6 [build link]
bladest
(@bladest)
Hi can you give it a try with latest big sur and i movie so i can see if it works only 1 case not 2 i  will be using.
bladest
(@bladest)
I really need some information since i will buy soon the case and i dont want to end with unusable brick case and gpu... with crashes on mac mini big sur os...
Mini i5
(@mini-i5)
Prominent Member
@bladest
No one is using an eGPU with iMovie. Don’t spend the money.
bladest
(@bladest)
I do understand, but my other option will be to buy very expensive Mac pro which i cannot pay at the moment,, please advice...
i just want to know will  my imovie render fast and will it stable or it will crash a lot of people is using imovie with external gpu
Mini i5
(@mini-i5)
Prominent Member
@bladest,
3C5986E9 00B8 49EB AD62 44E8406176EE
@bladest, an eGPU causing crashing will rarely be brand/vendor specific so if there is an issue with iMovie a different eGPU isn’t going to change things.
people usually use egpus for pro apps or games so getting data on iMovie usage may be a struggle.
sorry I can’t be of any more help.
