Like many others, I am plagued with the horrible PSU fan noise of the Mantiz Saturn Pro.
Does anyone advise any particular PSU? I thought the Seasonic Focus GX 750 would be a good alternative. I bought it but had to return it because had a loose piece inside the PSU enclosure (bad luck I guess).
Please let me know your thoughts on what PSU to get. I am running a RTX 3080 FE.
Cheers
.hi, @francisco_olavo I think you have already chosen the best PSU - the Focus GX 750 is very highly rated. Small, same size as the original PSU so it fits the Saturn case perfectly. Other manufacturer’s similar spec PSU are bigger. Yes you got a bit of bad luck with the faulty unit but I would exchange it for another one.
Corsair TX750M is another option but not as good as the Seasonic, Corsair SF750 probably quieter and so better than the TX but it will need ATX to SFX adapter and fan may not align with Saturn fan bracket.
I would also suggest changing the stock Saturn case fan for something like the be quiet! Silent Wings 3 120mm Quiet PWM, these two modifications should mean the Saturn enclosure runs pretty much silent so you will only hear it when your chosen GPU is under load and the GPU fans spin up.
Good luck.
.@dalyboy, thanks. Regarding the case fan, I have already exchanged it for the Noctua nf-a12x25. Besides the horrible caqui color, seems to have great performance. I guess is a bit more noisy than the Silent Wings3 but also has more efficient airflow.
.I got a SeaSonic Focus PX-850 -- it's dimensions are identical to the stock PSU. I highly recommend it.
You can check my activity for my story/pictures.
MacBook Pro 16" - 2.3 i9, 16GB, 1TB, 5500m (I added thermal pads to the VRMs); Mantiz Saturn Pro w/ PowerColor Red Devil 5700 XT (previously, a Gigabyte RX 580 Gaming Box) + LG OLED C9
More silent?
my awesome Radeon VII eGPU
More silent?
Yes, the GX is gold rated, PX is platinum rated. Both offer a ‘hybrid’ mode which only spins the PSU fan when the load requires. Much like the stock Saturn PSU.
Both will be quieter than the Saturn stock PSU - even the fixed version without the annoying fan noise. Most stock fans are cheap parts I find.
I’m not sure whether the PX is quieter than the GX but being platinum rated it should be more efficient (but probably more expensive too). The GX is very efficient and quiet for a fairly compact gold rated PSU already.
The Saturn stock PSU is gold rated 750w, the ‘best’ specification matched replacement in my view is Seasonic GX-750. PX-850 used by Arzen is higher specification than GX-750; so it is an upgrade to the stock spec..
.I refer you to my "RMA" experience here regarding delivery. After testing the new PSU for a week or so, I can say it is much better, without much of the rattling noise, but will still kick off the fan at random and I'm sure that will not change given the replacement was the exact same model from FSP, just without a bad ball bearings fan most likely.
I am happy that Mantiz sorted this out, but I am not happy I had to send them the PSU at the same day they shipped the replacement. I was without use of the enclosure for about 6 days, and despite my own shipping to DHL being straightforward (despite the number to arrange pickups not being free...), the return replacement shipping ALMOST caused me to have a freakin' breakdown as you can read on the post I link. Mostly DHL's fault, but I would have not had these problems had Mantiz used the same means they initially did to ship the item from Germany, instead of extra-EU Taiwan.
I will most likely be replacing the PSU in the medium term, as I want something that doesn't "pulse" the fan and is either constantly on, or never on. My 3070 inside doesn't need it, and my target laptop only consumes about 45W. I'll probably get something less powerful and more modular, and will see if the original PSU can be used for some small form factor room VR build I'm considering later.
I would advise anyone with the problem to contact Mantiz ASAP as I woudln't be surprised they drop the ball on supporting this soon. They seem to no longer be offering enclosures for EU shipping, and this may be for the obvious costs it costs to RMA here with delivery duty paid. Of course, this only applies if you are EU-based, wanna go through the problem of dealing with DHL/customs risk of you having to pay something (but I'll be fair, I ended up not paying), and/or are already considering a PSU mod yourself with something less noisy.
If anyone is interested, I can share "before/after" recordings of the sound difference.
