Mantiz Venus - Sep 2017 firmware with full 22xxMiB/s bandwidth (archive)
 of  3
Just noticed Mymantiz_John has removed this full 22xxMiB/s bandwidth firmware from his blog.  This firmware has been proving to be problematic with I/O ports as can be seen by user reports below:
In the first link above we see he has been reverting some users back to the previous 15xxMiB/s bandwidth firmware which statically allocates a large chunk of bandwidth for port use. This 22xxMiB/s firmware was supposed to dynamically allocate bandwidth for I/O ports as they needed it.
Some users want full eGPU bandwidth and don't care for the I/O ports.
Thankfully we have his original blog firmware post announcement archived at http://archive.is/YV69Z , snippetted below and this full-H2D firmare attached.
Mantiz Venus New firmware is released
by John Li September 14, 2017 https://mymantiz.com/blogs/news/mantiz-venus-new-firmware-is-released%23comment s">22 Comments
Finally, we got the Intel Sign. Here's the FW with Dynamic Control.
Download https://drive.google.com/open?id=0B1s-cMG0OPjFQU0xRzBNekNvTG s">Here
How to:
In Window 10
1. Connect with your Mantiz Venus
2. Make sure that Thunderbolt device manager had been recognized the device.
3. Unzip the firmware update tool.There will be two files, unzip them into the same folder.
4. Execute the FwUpdateTool_TBX-550CA_NOMOD_Mantiz.exe.
5. Follow the step, then Done.
Note:
* Mainly for increasing the band width from Host ( Laptop ) to Device ( Mantiz Venus )
Mymantiz_John originally announced this upcoming firmware in July-2017:
Posted by: Mymantiz_John
Posted by: moffat
Excellent to see those tests, I think the performance hit may come if you are running a game at High FPS / low quality where the transfer speed would be more of a bottleneck.
HI, Please check the bench mark by
Heaven Benchmark
API: DirectX11
Quality: Low
Resolution: 640x360
Current FW: H2D 15xx Mib/S
 2017 07 25 下午5.02.08
Result:
 2017 07 25 下午5.03.59
Upcoming FW: H2D 22xx Mib/s
 2017 07 25 下午5.05.53
Conclusion:
No difference in Low Quality & High FPS.
Please enjoy those extra Ports and its convenience. ^_^
Mymantiz_John
(@mymantiz_john)
Vendor
we remove it because it will make confusion, all the shipment form July is using the Full H2D firmware, so we think it had been lasting for along while, so it doesn't need to be there.
Mantiz: ● ●
ikir
 ikir
(@ikir)
Prominent Member
I’m using dynamic allocation firmware without issue on Sata and Ethernet. Sometime I got some USB-A he dusconnected but no issue with my mouse, iPhone dock and headset.
my awesome Radeon VII eGPU
dbuckingham
(@dbuckingham)
Are there more tests out there that compare the effect of the different bandwidth on game fps?
2017 15" MacBook Pro (RP560) [7th,4C,H] + GTX 1080 @ 32Gbps-TB3 (Mantiz Venus) + Win10 [build link]
dbuckingham
(@dbuckingham)
@nando4 Is this the only/latest firmware I can apply for the Mantiz, or have there been any new developments? Because I'm experiencing half H2D bandwidth (well more than half - 16xx instead of 22xx) on my Venus.
@mac_editor I believe the firmware from late 2017 is the newest. I also have a .bin version saved too if needed. The FWUpdateTool requires the Intel Thunderbolt Software [17.4.77.400]. It gets complicated when you want to switch to Thunderbolt Software Control later so make a Restore point. Once you finish flashing the firmware, go back to the non-Intel Thunderbolt Software restore.
@itsage
Thank you. I’ve not been using any Thunderbolt software so far. The instructions provided by Mantiz mention disconnecting the GPU for this. Is this needed?
@mac_editor I believe Mantiz followed the steps I wrote in this FW upgrade guide. Things have changed quite a bit since [new procedure]. You can download Intel Thunderbolt Software. Make sure the Thunderbolt enclosure is connected and active then you're good to go.
 of  3
