[NEED HELP] Config RX580 on eGPU (Razer Core X Chroma) running on Bootcamp in Ma...
[NEED HELP] Config RX580 on eGPU (Razer Core X Chroma) running on Bootcamp in Macbook 13" 2017
imthanhbinh
(@imthanhbinh)
Hi there,
I am currently looking for installing my eGPU setup containing AMD RX580 on Razer Core X Chroma case. I've read some tutorials in this community but most of them are out-of-date. Could someone help me to config it properly, please? I am happy to pay a fee for your time.
My Macbook Pro 13inch specs:
CPU: i7 @ 3.5Ghz
RAM: 16GB
SSD: 1TB
Thank you for your attention.
Topic Tags
If you head over to the builds section you should find the latest builds for your set up.
I have the same laptop and have done one recently with an RX560 and Vega 56 (link in sig).
