Hi All,
I have the following setup
I get a black screen as I plug it in and it restarts + and goes on a loop.
Any help would be appreciated.
Thanks in advance.
@naeem_noor, It's likely an issue with the XFX GPU firmware. If possible, flash the vBIOS with one from Sapphire or one with matching VRAM manufacturer.
@naeem_noor, You can try it in Windows Boot Camp. I don't think error 12 prevents ATIFlash from working.
Hi @itsage,
I'm getting an error while flashing 'subsystem id mismatch'. I tried to flash this sapphire bios. Here is a screenshot of my GPUZ and SRBPolaris.
Thanks in advance.
@naeem_noor, Keep looking for one that may match the memory brand on your XFX card.
@naeem_noor, that's exactly what I addressed in my post: If you have a XFX RX 560 4GB you Must see this
Macbook Pro 15" Late 2013 - Intel i7-4850HQ @ 2.3GHz - nVidia GeForce GT 750M 2GB VRAM - 16GB RAM DDR3 @ 1600MHz - Custom eGPU enclosure with JHL7440 chipset - XFX RX 560 4GB VRAM @ Sapphire VBIOS
