Omen Accelerator USB/GPU lag solutions?
Karim Fatehi
(@k_electron)
Just started using a gtx 960 in an omen accelerator with a spectre x360 (8550u) with the supplied tb cable.
having a couple of issues:
1 - usb devices connected to the accelerator are lagging. the mouse stutter is especially bad.
2 - game graphics tear occasionally (same card works fine on these older games like age of empires HD on a desktop)
any solutions or things i am missing?
4chip4
(@4chip4)
Is that a 13" or a 15" Spectre? 1) is a result of the Intel chipset/drivers used in this generation of TB3 enclosures in general, so likely no easy fix there other than getting a separate USB hub for lag-sensitive accessories. As for 2), most performance issues stem from bandwidth bottlenecking - if you're bringing the image back to the internal display and not switching from 4K to HD, or you have a lot of HDD activity going over TB3, that might seriously eat into the GPU bandwidth (especially if you have a 15" x360).
2017 HP Spectre x360 15 i7-8550U GTX150 + GTX970@16Gbps-TB3 (HP Omen Accelerator) + Oculus Rift + Win10 (no guide)
HP Omen Accelerator Thunderbolt 3 enclosure legs stand removal walkthrough
Thomas Burgess
(@ninjinka)
I THINK I FIGURED IT OUT.
I went to Control Panel > Hardware and Sound > Power Options > Change plan settings > Change advanced power settings > PCI Express > Link State Power Management
I then switched "Plugged in" from "Maximum power savings" to "Off"
I also switched turned off "USB selective suspend setting" under "USB settings" but I think it was the PCI Express settings that fixed it.
I did this on the Huawei Matebook X Pro and it seems to have solved any input lag problems I had. I stumbled upon this solution by accident, when I was trying to figure out why my backlit keyboard was timing out. Let me know if this works for you!
2018 14" Huawei MateBook X Pro (MX150) [8th,4C,U] + GTX 970 @ 16Gbps-TB3 (HP OMEN Accelerator) + Win10 [build link]
tonguecat
(@tonguecat)
Posted by: Ninjinka
Sadly, that doesn't work for me. Still lagging when playing games (Overwatch).
HP Spectre x360 – 13-ac033ng (Intel Core i7-7500U @ 2.70GHz | 16GB | 512 GB NVMe) + GTX950@32Gbps-TB3 (OMEN by HP Accelerator)
rabbeleet
(@rabbeleet)
On my laptop, Lenovo YOGA 920-13IKB, i dont have "PCI Express" option under "change advanced power settings". I only have; Desktop background settings, Sleep, Power button and lid, Display and Battery.
I dont even have gpedit.msc, so i wanted to upgrade from Windows 10 Home to Pro in order to get gpedit.msc.
I updated to Windows 10 Pro, and the mouse lag disappeared... at least almost. My gaming mouse stil lag, but the HP-mouse i got from work is now working without any lag!
I also found this link: https://forums.windowscentral.com/microsoft-surface-pro-4/393034-where-my-advanced-power-options.html
I have not tested that yet, but if the mouse start lag again, then I'll test that too.
Cheers!
