Question: Sonnet 2 slot egfx breakaway box 350w enclosing EVGA RTX 2070 XC Ultra
Ian Chen
(@ian_chen)
Hi I stupidly bought an EVGA RTX 2070 XC Ultra without checking compatibility with my enclosure. Now I realized the 3 prong bracket won't fit into the enclosure. I am so desperate. Should I get a jigsaw or a nibbler and cut my enclosure to fit the gpu?
No. return it and buy a card that fits, you'll regret hacking it up in the long run and if you have any issues your warranty will be voided.
Jyin
 Jyin
(@jyin)
Sonnet BB is very easy to mod without voiding warranty.
What I did was to remove the PCB from it and transferred it to a PC case.
C011A4CF 0BFE 41BD AD54 E610A50A0457
You can do something simillar, or you can get some PCB riser screws and let the GPU sit bare with no enclosure.
You can also remove the back bracket from the GPU without voiding warranty.
The GPU will fit in the Sonnet BB then. You will just have to be careful plugging in the cables, and/or moving the eGPU.
J
2017 27" iMac 5K (RP580) [7th,4C,K] + RTX 2080 Ti @ 32Gbps-TB3 (Sonnet Breakaway 550) + Win10 [build link]
