Razer core X and gaming z trio 2080 ti pin problem
Benoit morinio
(@benoit_morinio)
Hello,
I can't get my build working windows isn't heaven recognizing the card, the ventilator rotate at boot then stop. The problem is probably that the card require 2x8pins and 1x6pins, and the razer core x only have 2x6+2pins.
Should I get a Y adapter in order to fill the remaining 6pin?
Thanks.
Topic Tags
@benoit_morinio, Yes, get a PCIe Y splitter adapter and connect the third 6-pin power plug.
Calvin Or
(@calvin_or)
@benoit_morinio, how did this go? did the y splitter made it work?
