Razer Core X Chroma - Fan Question - 2 | 3 | 4 Pin Connectors
noveske
(@noveske)
Have a Core X Chroma. Core X Board has a 3-pin.
Running a GTX1080 Hybrid which I believe is a 2-pin.
Wanted to get ML120 / ML140 Fans. Seeing if the LED ones would work.
I'd assume the ML140 to the 3-pin on the CoreX board would work but just run at 100% since the 4th wire is PWM.
ML120 to the 2-pin for the Hybrid should run as the 3rd wire is for control or it's actually a 3-pin.
I was thinking about using Noctua Low-Noise Adapters and Manual Controller.
Everything would just run from the 3-pin on the board to the 2 fans.
2018 Intel NUC8i7BEH [8th,4C,U] + GTX 1080 @ 32Gbps-TB3 (Razer Core X Chroma) + Win10 [build link]
