Sonnet Breakaway Box 550 / Sapphire Radeon RX580 Nitro+ Special Edition 8GB Powe...
Sonnet Breakaway Box 550 / Sapphire Radeon RX580 Nitro+ Special Edition 8GB Power connectors?
NostromoUK
(@nostromouk)
This has been a great forum for me to learn more about EGPUs, so thank you for being here.
I have installed my RX580 Nitro+ into the Breakaway Box 550 but am unsure which of the power connectors to plug into the GPU.
The Breakaway Box has 2x '6 pin(yellow) and 2 pin (black)' ...whilst the GPU has 6pin and 8 pin connections next to each other.
Can some wise person advise me which connectors I plug into the GPU?
Famed Member Admin
Those PCIe power cables have 6+2-pin connector. Join one 2-pin to 6-pin and connect them to the 8-pin receptacle on the GPU. Then plug the 6-pin connector to the 6-pin receptacle on the GPU. Let the unused 2-pin hang loose.
109 external GPU build guides
NostromoUK
(@nostromouk)
A huge thanks for replying, itsage.
That seemed to be the only way it could connect..but just wanted to make sure before I blew it.
Does it matter in which combination the yellow and black are placed on the GPU? ie: black 2 pin to the left?
Yukikaze
(@yukikaze)
Prominent Member Moderator
There should only be one way for it to fit due to the shape of the pins, but the extra 2 ground (black) pins should be to the left of the connector (when looking at the connector from behind - the side where the wires enter the connector).
You can see an example here.
My eGPU Zoo - Link to my Implementations.
NostromoUK
(@nostromouk)
Thank you, Yukikaze - I realised that may have been a dumb question when I realised it only goes one way!
Again, I appreciate both of your help and answering so quickly. This forum is brilliant.
Have a great day.
Yukikaze
(@yukikaze)
Have fun and game on 🙂
