Zbook with Discrete NVIDIA card (Qudro M2000M) with egpu problem
ipsych
(@ipsych)
I am connecting the egpu enclosure (Titan V) to zbook with quadro M2000M.
I followed the guide,
( https://egpu.io/forums/thunderbolt-linux-setup/ubuntu-19-04-easy-to-use-setup-script-for-your-egpu/ )
but whenever the egpu connected and selected, the screen blinking and egpu fan runs to its full speed.
the same egpu enclousure works perfect with Nuc 7 via thunderbolt3.
Is there special concern with the laptop already with discrete NVIDIA card?
ZBooks (not sure which is your Gen) tend to have quite flexible BIOS where can set GPUs as:
  • iGPU only
  • iGPU + dGPU (Optimus)
  • dGPU only
You may consider testing the iGPU only mode with the linux configuration script for the eGPU.
ipsych
(@ipsych)
@nando4
Thanks. This is the most headaching part.
The bios support ,
1)auto
2)discrete
3)and flexible switching.
I think it doesn't support igpu only mode.
 Also my purpose is not a gaming, so if NVIDIA-SMI and cuda can detect eGPU, I am fine...
[Update]
I think that I found the problem.
https://egpu.io/forums/pc-setup/akitio-node-gtx-1080-ti-hp-zbook-15-g3-help/
Using quadro and TitanV seems not possible.
I have to change to 965m and re-test it.
This post was modified 11 months ago
