Best compatible gear for internal displa...
Best compatible gear for internal display/acceleration on Mojave and Win 10
caio
 caio
(@caio)
Mar 28, 2019 10:41 pm
I have a 2017 13" Macbook Pro Touchbar with Mojave and Windows 10.  I don't have an external screen and I am looking for something more compatible with both OS's.
I am thinking about Razor Core X and a Vega 64 but I have some questions:
- Is it the best option?
- Do I still need to buy those headless ghost adapters to use internal display?
- I read in some 2018 Macbook Pro @theitsage's  builds that he disabled "PCI Express Root Port #3 - 9DBA [wireless card]" to make it work. Is it necessary? I will be without wireless connection?
- Is there already a way to make Nvidia cards work on Mojave?
Thanks everyone!
OliverB
(@oliverb)
Mar 30, 2019 11:55 pm
Posted by: caio
No.
No. Except for Kepler cards (most of 600er, 700er series). They always worked.
No, it's not!
@itsage why is it supposed to be necessary to disable PCI Express Root Port #3 in a 2018 MacBookPro?
This post was modified 3 months ago
Noble Member Moderator
Mar 31, 2019 2:35 am
Posted by: OliverB
No, it's not!
@oliverb It was done to keep all Thunderbolt 3 ports active on the 2018 13" MBP: https://egpu.io/forums/builds/mid-2018-13-macbook-pro-rx-58032gbps-tb3-gaming-box-w10-1803-theitsage/
@caio may have just misinterpreted it as a requirement.
Command Line Swiss Knife
eGPU Hardware Chart
Multiple Build Guides
Current: MacBook Pro RP560X + 480/R9 Fury/Vega 64 | GTX 780/1070
Previous: 2014 MacBook Pro 750M + 480/R9 Fury | GTX 780/980 Ti/1070
OliverB liked
OliverB
(@oliverb)
Mar 31, 2019 8:55 am
@mac_editor it was done to keep all 3 Thunderbolt ports active on the 2018 13" MBP?
I don't understand, they should be kept active without doing such thing. I think it's is not only not necessary on W10 1803, it doesn't bring anything other than there is no Wirelass Lan. Perhaps on November 2018 there was the common sense that there must be done something, but it's not.
Then again and again this happens:  New eGPU Users read such stuff, misinterpret and nothing works anymore ¯\_(ツ)_/¯
