Best eGPU set up for a Pro Display XDR?
twentyonekoala
(@twentyonekoala)
Hello!  I am currently using my MacBook Pro 16 i9, 5500m, 32gb ram with a Pro Display XDR.
Having some trouble locking down a good eGPU setup for high resolution gaming (mostly WoW).  Any solutions that would allow me to take advantage of the Pro Display XDR's thunderbolt 3 connection?
Mini i5
(@mini-i5)
Prominent Member
@twentyonekoala
Blackmagic had the only eGPU enclosure with a TB3 output. You don’t want that one.
Its possible Apple and Blackmagic might design a new model with a next-gen AMD card to use with the XDR. But there’s no plans or rumors at this point.
2018 Mac Mini + AMD RX 6600 XT (Sonnet Breakaway Box 650) Monterey 12.1 pending + Windows 21H1
2018 Mac Mini [8th,6C,B] + RX 6600 XT @ 32Gbps-TB3 (Sonnet Breakaway 650) + macOS 12.0 & Win10 21H1 [build link]
twentyonekoala
(@twentyonekoala)
@mini-i5, Thank you very much for the response!  Really wish the 5700xt had a TB3 output.  I suppose the best option here is to just wait.
Mini i5
(@mini-i5)
Prominent Member
@twentyonekoala
Yeah, we’re stuck waiting for fresh gear at this moment.
@twentyonekoala, use 5700 XT with Belkin VR2 cable. The only thing you'll miss is USB 3.0 from the USB ports of the XDR display - they'll work at USB 2.0 speed though.
https://forums.macrumors.com/threads/egpu-and-apple-pro-display-xdr.2229210/page-2?post=28803374#post-28803374
Mini i5 liked
Mini i5
(@mini-i5)
Prominent Member
@joevt
Very cool. Good info.
@twentyonekoala
So, with this special cable, you can choose any enclosure you like to pair with an RX 5700 XT
Good Times.
twentyonekoala
(@twentyonekoala)
@joevt Would the Radeon Pro w5700 work alright with the USB-C output on the card?  Really leaning toward that card to pair with the XDR.
@twentyonekoala, should work fine.
https://forums.macrumors.com/threads/amd-radeon-pro-w5700s-usb-c-port-and-pro-display-xdr.2222125/
