Cheapest eGPU to fit GTX 1080 to work w/ 2019 MacBook Pro
D3monw3st
(@d3monw3st)
As the title states. Thank you!
Check the eGPU.io Buyer Guide.
Choose an eGPU that uses a TI83 instead of a TI82 because TI82 is not compatible with macOS.
Follow this instruction for choosing GPU max power3:
3 Meet or exceed your intended video card's peak power requirements. See TechPowerUp card reviews, eg: GTX1080Ti to find this.
For a 1080 that isn't overclocked, maybe 225W is enough for GPU max power.
Check the Builds page for builds that include the 2019 MacBook Pro. Select Apple for brand, select MacBook Pro for model, and filter using "2019 " with a space character, for model year.
I found only two:
https://egpu.io/forums/builds/MacBook-pro-2019-13-8th4cu-rx-vega-5632gbps-tb3-hp-omen-accelerator-macos-win10/
https://egpu.io/forums/builds/2019-13-MacBook-pro-8th4cu-rx-48032gbps-tb3-visiontek-mini-egfx-macos-10-14-5-win10-1903-itsage/
Then search AmazoneBay, etc., for current prices and deals for your top 5 choices. Maybe there's something in https://egpu.io/forums/for-sale-wanted/
D3monw3st
(@d3monw3st)
@joevt
Yeah, I was wondering if this: https://www.aliexpress.com/item/33047416121.html?spm=a2g0o.productlist.0.0.17793556OqiNXK&algo_pvid=3ce7bc36-bac4-4a7c-b4cd-57e6b721a4f7&algo_expid=3ce7bc36-bac4-4a7c-b4cd-57e6b721a4f7-3&btsid=5e849a00-5b08-4a01-816b-80f57420f456&ws_ab_test=searchweb0_0%2Csearchweb201602_8%2Csearchweb201603_52 would work? I would then buy a PSU and maybe build my own enclosure?
@d3monw3st
MacBook Pro doesn't have NVMe slot. You would need the R43SG-TB3 version which does not save you much money compared to an eGPU.
https://www.adt.link/product/R43SG.html
D3monw3st
(@d3monw3st)
@joevt
Ah right, okay. So what's the most cost-effective eGPU? Anything around $200?
@d3monw3st
The one with the lowest price? Availability, quality, cooling, power, features are also considerations.
