Could i fit a RTX 3080 into a razer core x chroma? would it make the RTX slower?...
Could i fit a RTX 3080 into a razer core x chroma? would it make the RTX slower? I'm using a Razer blade 15 (2019 mid)
NSA Agent
(@nsa_agent)
noveske
(@noveske)
Posted by: @nsa_agent
Razer Core X Chroma max inner dimensions:
Length : 12.99”/ 330 mm
Height*: 6.29” / 160 mm
Width : 2.24” / 57 mm
General 3080 Dimensions:
Length: 11.4" / 285mm
Width: 4.4" / 112mm
I'd say yes. Gonna assume here that Nvidia's measurement of width is the slot width and not the actual height. That the width of the card is measured and Nvidia measured height with the card laying on it's side in the case.
2 builds on the front page build database:
https://egpu.io/forums/builds/2019-xps-13-9380-rtx-3080-32gbits-s-tb3-razer-core-x-win10-1909/
https://egpu.io/forums/builds/2017-acer-predator-triton-700-gtx1080-maxq-7th-4c-rtx-3080-gbps-tb3-razer-core-x-chroma-win-10/
2018 Intel NUC8i7BEH [8th,4C,U] + GTX 1080 @ 32Gbps-TB3 (Razer Core X Chroma) + Win10 [build link]
