Does length matter? - Thunderbolt Cable Length
comfycat
(@comfycat)
Hey, I've got a Aorus GTX 1080 Gaming Box running off my 2013 Macbook Pro 13", via TB3 > TB3 adapter... It's running great, but I'm having an issue with intermittent lag, where the game hangs for a full second or two, apparently while loading textures or autosaving (or both). I know the TB2 I'm using is a bottleneck, as is the older 2.4 GHz Intel Core i5 I'm running it on. My question is, can I improve this any by using a shorter TB2 cable? Right now I'm using a 2m TB2 cable (after the adapter), just because I thought my setup was going to be farther apart. Currently I could be using a 0.5m cable, but before shelling out another $26, I'm wondering if it will make any difference. I notice folks are using short cables, but does it really have an effect at these small distances?
You've been warned.
late-2013 13" MBP Retina + [email protected] (Aorus Gaming Box via TB3>TB2 adapter) + macOS10.13.3 & Win10
2013 13" MacBook Pro [4th,2C,U] + GTX 1080 @ 16Gbps-TB2>TB3 (AORUS Gaming Box) + macOS 10.13.3 & Win10 [build link]
What's the brand of your current 6' TB2 cable? I have two sets of TB2 cable + TB3 «» TB adapter and have not noticed much difference. They are all Apple brand.
comfycat liked
comfycat
(@comfycat)
@itsage I'm using StarTech.com brand TB2 6' cable; they're not cheap. The adapter is Apple; only adapter I found that would work for this application. So you're saying with different length cables you didn't notice a difference in throughput?
You've been warned.
