[Egpu vs gaming laptop] How much of a performance can I realistically expect? (M...
[Egpu vs gaming laptop] How much of a performance can I realistically expect? (MBP 15 + EGPU vs Razer blade pro 17)
cocosoy
(@cocosoy)
So here is my dilemma:
I have the 2016 MBP 15 (TB), I am thinking about getting a EGPU with RX 5700 XT
I wondering if anyone knows how much the aforementioned setup would out perform a Razer blade pro 17 (with 2080 Max Q)?
Or the RBP with 2080 still beats my MBP with RX 5700XT?
Any insight is welcomed!!
John
ICULikeMac
(@iculikemac)
Mmm it would be quite close I would imagine, much easier on the blade. This is putting the MBP in Bootcamp right?
2019 Razer Blade Stealth GTX1650 Win10
Aorus Gaming Box RTX 2070
Asus XG Station Pro (RX570 8GB + RTX 2080)
cocosoy
(@cocosoy)
@iculikemac, Yes, planning to use bootcamp for windows gaming~ Thanks for the insight buddy!
andygev35
(@andygev35)
There are a few aspects to consider.  The RBP will likely perform a little stronger, but once you have it, that’s all you’re gonna have.  There’s no ability to future-proof, although it’ll would serve you well for several years.  The MBP with eGPU can get an upgraded external screen and GPU at any point so it would be pretty much future proof to a point.  There are also other options with non-gaming laptops with thunderbolt 3 that could support the eGPU as well.  The choice is yours, and there are a lot of different directions you could go.
2020 MacBook Pro, i5-1038NG7, 16GB RAM, 1TB
Razer Core X
Sapphire Pulse RX 5700 XT Dual BIOS
2020 13" MacBook Pro [10th,4C,G] + RX Vega 56 @ 32Gbps-TB3 (Razer Core X) + macOS 10.15.4 & Win10 [build link]
For gaming, RBP 17 with GTX2080-MAXQ spanks the MBP + RX 5700 XT eGPU. See why TB3 underperforms for gaming at:
https://egpu.io/forums/builds/2015-15-dell-precision-7510-q-m1000m-6th4ch-gtx-1080-ti-32gbps-m2-adt-link-r43sg-win10-1803-nando4-compared-to-tb3-performance/
tsakal
(@tsakal)
@cocosoy  wiht my mbp13 and razer 570xt running bootcamp on ext ssd, I get consistenly 90-120 fps ~high settings with f1, projectcars2, horizon4, at 1440 with a Samsung 65' 120 tvset.
A) 2020 MacBook Pro, i7-1068NG7, 32GB RAM, 1TB, EGPU Razer Core X, Gigabyte OC 3080 10Gb, Samsung 49 1440p UltraWide C49RG
Mac OS Catalina 10.15.7, Internal Bootcamp Windows 10 latest update previously W10 2004 pci.sys swap.
B) 2.7 GHz I7 4 Cores, 16Gb, 1TB MBP 13 2018 TB3 , EGPU Razer Core X, Nitro+ RX5700 xt 8Gb, LG 32UK550
C) 2.7 GHz I7 4 Cores, 16Gb, 1TB MBP 13 2018 TB3 , EGPU Gigabyte Gaming Box RX580 8Gb, Mac OS Catalina 10.15.2, Ext SSD Windows 10 1803
D) 3.1 GHz I7, 16Gb, 1TB MBP 13 2015 TB2 , EGPU Gigabyte Gaming Box RX580 8Gb
cocosoy
(@cocosoy)
@nando4, wow really helpful link! Thank a lot man!
@andygev35, you are absolutely right, both have its pros and cons. I don't have an external monitor at this moment, so getting a gaming laptop which comes with a high refresh rate monitor sounds tempting Smile
@tsakal, thanks for the benchmark! that's some really good fps you are getting.
