How good does it work? What works exactly?
willhaben
(@willhaben)
Hi Guys,
i got a couple of questions and i would appreciate it if you can help me.
Current Situation
First let me give you quick an overview of my current situation.
Actually i am using 2 devices. A Macbook pro 15" wich is my daily driver for business and private stuff ( except gaming ).
The second device is a Windows Desktop wich is basically my gaming device. I am playing mostly FPS Games.
What would i like to have?
I would like to get just one device for everything. The idea having just one small / light weight Notebook for everything ( My favourites are ->  Razer Stealth and Macbook Pro 13 ) and just one cable to plugin to get a "Desktop replacement" is wonderful.
My preference would be a Macbook Pro 13 since i can install Bootcamp / Windows 10 there and switch between both os. So i am more flexible.
But i have my doubts due the Hardware and OS.
But keep in mind please, i  prefer a working system over a not working one :-).
How good does it work? What works?
  1. I have read that the stealth 2019 got the much better cooling due some "big" fans inside the stealth and the positioning.
    Wich means in theory for longer gaming sessions with games like PUBG could it helpful that the Notebook has a better cooling.
    Does anyone have here some experiences? Is the Razer stealth better for gaming with an egpu?
  2. Is a Ultrabook / egpu combination reliable? Reliable in terms of stability? I have read quite a lot that display turns of, that the gfx is not detected etc etc.
    Is it aswell a matter of the OS you use? OSX vs Windows 10 for example?
    What can you recommend me?
  3. I have seen mostly short thunderbolt cables plugged in beetween notebook + egpu.
    Can a longer cable between egpu and notebook effect the performance? For example 1m.
  4. How significant is the CPU difference / performance between the 8565U and 8559U?
    I have read a couple of Test and Pages like https://cpu.userbenchmark.com/Compare/Intel-Core-i7-8565U-vs-Intel-Core-i7-8559U/m591977vsm543591
    But i would like to get some real gaming results / experiences.
  5. Have someone experienced some lagging / latency issues in FPS Games due Thunderbold limits?
    I am not talking about the ping / packet loss etc. I have read that the thunderbold connection got i limits and since its not directed plugin there might be latency issues.
  6. Could a Razer Stealth / macbook pro 13 in combination with a 2080 or 2080ti enough for 1440 Gaming? Some have here some fps benchmarks. I always prefer having low setting and high fps.
Thanks in advance!
This topic was modified 5 months ago
When I rad your thread title I thought it was going to be another "het guys will this work thanks" with no context or details but this is a cracking post.
I can't help with all the questions but I can give you an answer to what is essentially your base question.
A MacBook Pro 13inch with an eGPU will give you a solid gaming experience at 1440. Source: Me, playing PUBG for hours, at 60fps, with my 2017 MBP and Vega 56 and the double bottleneck/performance hit of a non directly connected TB3 monitor.
In more detail..
  1. Mine runs fine, how long it lasts only time will tell (will I cook my laptop?).
  2. Varies dep on set up, I have very very few issues, in the year or two I have used an eGPU I have had prob only a dozen or so game crashes due to them. Yes, about a dozen, I had more troubles when I used an actual PC!
  3. I use a 2M cable and have no issues. Tests were done somewhere on here and the difference was around 1-2 fps at most.
  4. No idea I'm afraid, I run a dual core which is way less powerful, so my findings are worst case - your set up will perform far better.
  5. Over my head im afraid.
  6. From what I have read 2080ti is overkill due to bottlenecking with TB3 and Laptop CPUs, sure it performs better than a 2080- but not by much. 2070/2080 is the sweet spot.
Hope that helps! I have some benchmarks in my build guides that might be of interest...
(I am sure you are aware - but there is no RTX support in macOS so you'll only be able to use it in Bootcamp, which is also what I did for years).
OH, and once you get it all working, eGPU.io PUBG Team? 😉
willhaben
(@willhaben)
I know... the choosen Topic might be not the best but didnt know any better :-). At least for now, you answered and helped me already.
Thanks for that! 🙂
Does you CPU / Macbook throttle during you PUBG Sessions? What settings do you use in pubg? Incase you use high / Ultra details, could u make a benchmark with competitive Settings?
Graphics Settings
  • Display Mode: Fullscreen or FullScreen Windowed
  • Resolution: 1920x1080 (monitor native resolution)
  • FPP Camera FOV: 90-100
  • Lobby FPS Limit: 60
  • In-Game FPS Limit: Unlimited
  • Smoothed Frame Rate: Off
  • Screen Scale: 100
  • Anti-Aliasing: Medium or High
  • Post-Processing: Very Low
  • Shadows: Very Low
  • Textures: Medium or High
  • Effects: Very Low
  • Foliage: Very Low
  • View Distance: Very Low
  • V-Sync: Off
  • Motion Blur: Off
  • Sharpen: On
Have u tweaked you Setup a bit more with for example the Radeon Settings:
AMD Radeon Settings > Gaming > Select PUBG
  • Anti-aliasing Mode: Use application settings
  • Anti-aliasing Method: Multisampling
  • Morphological Filtering: Off
  • Anisotropic Filtering Mode: Use Application settings
  • Texture Filtering Quality: Performance
  • Surface Format Optimization: On
  • Wait for Vertical Refresh: Always off
  • OpenGL Triple Buffering: Off
  • Shader Cache: On
  • Tessellation Mode: Override application settings
  • Maximum Tessellation Level: Off
  • AMD FreeSync: AMD optimized
  • Frame Rate Target Control: Disabled
And yes, whenever you want. Im up for a egpu.io PUBG Session 🙂
PS. I know that RTX not working in macos. RTA is nice but thats it for now. No needs for me. As i said.. i rather have high fps / high monitor refreshrate and low details on game then the opposite 🙂
PPS The Settings are from Maggie007 on Reddit. https://www.reddit.com/r/PUBATTLEGROUNDS/comments/9qf25x/pubg_detailed_guide_to_maximum_fps_how_to_boost/
OH BOY, that's a long post, and you know what? It prob helps me more than it helps you.. I kept meaning to find the best settings for PUBG and never actually got round to it and now it looks like, bam, you've posted them for me. Reminds me of my old DayZ days where I spent hours and hours tweaking every little setting to try and get double digit FPS on my MacBook Pro 2013 pre eGPU days.
Settings wise, I have a mix of everything, not sure if its great performance wise but I aim for 60fps while looking good. My monitor is only 60hz so no real point dropping settings to go over (I think?).
I haven't noticed any throttling, but thats not to say its not happening...
I'll try and get the benchmark done over the weekend. Couple of caveats...
I'll be running at 1440 and I have a double performance loss of not being able to connect my monitor directly to my egpu (due to it being TB3 only).
My monitor may be failing too, so might be in the market for a new one, if you have any suggestions for 4K 144HZ I'm all ears...
Oh and same name on steam!
willhaben
(@willhaben)
Posted by: Eightarmedpet
Your welcome 🙂
Would be awesome if you can do that whenever you have time.
About the Monitor:
If you talk about real 4K Monitor with 144hz i just heard about one Monnitor -> ASUS ROG Swift PG27UQ,
Cant help you with that subject since 4K Gaming is ... too much in my opinion.
Other monitors wich could be interesting for you with a higher resolution and decent colors are:
  • Dell S2719DGF ( free sync + TN Panel good for FPS Games bad for colors but this one is for a TN Panel really good )
  • Dell 2716DG ( gsync + TN Panel good for FPS Games bad for colors but this one aswell is for a TN Panel really good )
  • Dell Alienware AW3418DW ( IPS Panel with decent colors - Not enough for Design works but still good )
A friend of mine recommended me aswell this one -> ASUS ROG Swift PG27VQ, 27"
Currently i am using a Benq XL2411. Aswell TN Panel and fantastic response times / input lag. But ugly as shit and only 1080p.
Esreality ( Gaming Community ) has a nice hardware forum with a lot of threads about Gaming Monitors and sometimes really good explained. Maybe you want have a look there -> http://www.esreality.com/?a=post&forum=13
@eightarmedpet cant find you on steam.
To all other people, don't forget about my Topic here 🙂
OliverB
(@oliverb)
@willhaben will alles haben
willhaben
(@willhaben)
Posted by: OliverB
You signature looks quite promising. Do you mind to share your experiences? Thank you.
OliverB
(@oliverb)
Posted by: willhaben
Posted by: OliverB
@willhaben
The signature is a link, too and you can click on it with the result of most of my users builds. Some still are missing, though. Those may be interesting:
Radeon VII and GTX 1080 Ti compared in one build
A Build with GTX Titan Black, the best nVidia card for Mojave (ever?)
Setup Guide for Bootcamp
I’m listening to your national band right now - ramstien. I may have changed my steam to chrisbmx116
OliverB liked
OliverB
(@oliverb)
So the best ambassadors of Germany are Ramstein. Intriguing 🙂
Note: I have 4 (four) GTX Titan Black at the moment. I am trying to build the best nVidia card of all times for Mojave, with the best chip and a great EVGA ACX Cooler.
odin
 odin
(@odin)
If all you care about is playing games get a Windows notebook and an eGPU. You could even dual boot Linux and get most of what a Mac is really good at. But Windows will have WSL v2 later this year which should get you most of the way there hopfeully.
After using MacBooks for the last 11 years I've become increasingly disappointed with them the last few years. I still use a 2017 MBP 15 pretty much daily, but my Gram 17 dual booting Manjaro Deepin has pretty much been able to replace everything I was holding on to my Mac for (software engineering wise). If WSL v2 is all it's supposed to be cracked up to be, that might even stop me from dual booting. I've been using Linux on and off since the mid 90's on the desktop and just as long nearly daily for server workloads though so I'm pretty well versed in it, that might be a bias.
How well this decision works out for you really depends on exactly WHY you would want macOS. Using Windows instead will open you up to a world where the eGPU will work much more seamlessly and without headaches for any nVidia or AMD GPU. If Apple ever changes their stance on letting nVidia provide official drivers for macOS maybe that will change.
EDIT: actually change that to 12 years of MacBooks, the first one I had was the 2007 15" with the 8600GT (ugh...). Was still a great notebook even given BumpGate.
LG Gram 17 | Sonnet Breakaway Box 550 | Asus Strix RTX 2070 OC Edition | Win 10 Pro 1903 + Fedora 31 Dual Boot
Build Link
OliverB
(@oliverb)
@odin
is your name Wednesday by accident?
8600GT is a fine card, I have two 8400GS, still no Mojave support. This is not fine.
OliverB
(@oliverb)
@eightarmedpet
It is amazing what you can get with a good cooling. I put the EVGA ACX Cooler on a GTX Titan Black. Some fresh conducting paste, some OC and there you go: Not even trespassing 80° C:
Valley3015 TitanBlack
You can officially declare this as a new World Record for Kepler cards in Unigine Valley. A lot of poor Vega souls would sell their grandma for such score.
It's even more amazing how bad the nVidia reference coolers are.
odin
 odin
(@odin)
Posted by: OliverB
@odin
Wednesday? I don't follow.
8600GT was a fine card as long as it didn't fail. https://hardforum.com/threads/nvidia-bumpgate-comes-full-circle-how-to-get-your-settlement-money-inside.1550848/
Build Link
@oliverb I don't actually even like that type of music, just find the Art Direction for the Mein Land video fantastic...
@willhaben thanks for the info reg monitors.. I'm not expecting to play in 4K (i'd go half res) but couldn't go back to sub retina, I'll hunt through that link you sent.
I gave those settings a go, to be honest didn't make much difference with my set up 55-65 FPS, no wold drops, that's about it. Only gave it a quick 5 min match so can't comment on throttling, and there was a big update to instal so not sure how that effected performance.
Chrisbmx116 on steam.
Just tried something... Due to my screen being 5K I have always had it at 1/2 res based on the assumption that the pixels will line up nicely and it'll be a sharp img.
When setting res in game to 1080 it does indeed look crap.
But setting it natively to 1080 then in game to match it actually looks fine (I am sure some people will think i'm daft for not realizing/trying that way) and it yields a good enough performance boost.
Did a quick match and was a good 20fps more than in 1440... so 75-90. And that's after I cranked render up to 120 in game.
According to this 120 is the most anyone could ever hope for and 90 is a good high with a Vega 56, so while I am using "competitive" settings I feel 80-90 is pretty respectable.
OliverB
(@oliverb)
@eightarmedpet
I would have said, too, that 2560 x 1440p is a perfect resolution for a 5K display, because it's exactly the half. This is supposed to be easy mathematics, but I learnd, too, that 1280 x 720p doesn't look better than other non-native resolution on a 2560 x 1440p . I can't explain. It may have to do with AntiAliasing.
odin
 odin
(@odin)
Just because it's an exact factor in resolution doesn't mean much. The scaling will always use interpolation and it will never look "good". Try 1080p scaling on any 4K monitor, which should just be 4 pixels for every pixel, and it will look like garbage. The best you can do is run the game at 4K and hope the game includes it's own resolution scaling settings for the renderer (I think Doom 2016 has this ability). That way at least you might get 4K crispness for the UI elements and the 3d viewport will be scaled down.
Build Link
Honorable Member
I have an Apple 30" Cinema display with 2560x1600 resolution. There are two ways to do 1280x800 resolution.
1) A scaled resolution where a 1280x800 frame buffer is scaled up by the GPU to output a 2560x1600 signal. The GPU does some blurring/smoothing  processing.
2) A timing mode where a 1280x800 frame buffer is output unmodified by the GPU as a 1280x800 signal. The display scales it up to 2560x1600 by duplicating each pixel four times - there is no blurring.
Option 2 is nice if you want to see every pixel unmolested.
Option 1 is nice if you think Option 2 is too blocky. The kind of blurring you see is similar to the "Smooth images" option in the "Zoom" section of the "Accessibility" preferences panel. Zoom in so things appear four times larger, then try toggling the "Smooth images" option to see the difference.
A third option is to use a 1280x800 HiDPI mode which uses a 2560x1600 frame buffer where things are drawn 4 times larger. This is how Retina is done. Text is smoother because there are four times as many pixels to use.
