What are those single slot GPUs which can fit into a 3 slot Razer Core X and combined they have more computing power than aa AMD Radeon RX Vega 64?
Mac Pro 6,1 2.7GHz 4 Core AMD FirePro D300,
Razer Core X enclosure, TB2 -> TB3 cable,
AMD PowerColor Radeon RX Vega 64 8GB card
@infocean, The Razer Core X (and most eGPU enclosures) has only one PCIe slot that is close to triple-slot wide. You can't combine multiple single-slot wide GPUs in it. A multi-slot Thunderbolt 3 enclosure I'd recommend is the AKiTiO Node Duo. If you remove the front cooling fan and fascia, you can fit many double-slot wide cards. You'd also need a higher output PSU to handle the cards.
@infocean, afterburner card?
.@lock_macgregor, No. Just for math (matrix) computation and Blender rendering.
