What cable do I need to connect ADT-Link R43SG to an 8 pin GPU?
NOOOJASON
(@nooojason)
I’ve seen pictures of other people’s rigs, and I can’t tell what cable they’re using to connect the 8 pin GPU to the ADT-Link R43SG.
Is there somewhere I can get one of those 8 pin connectors too? If it helps to know, I’m using a GTX 1660 which also has an 8 pin.
A link would be great! 😀
WIP eGPU:
Y700-15ISK
EVGA GTX 1660 SC ULTRA GAMING
ADT R43SG
Dell DA-2
Topic Tags
Gergo
(@gergo)
As far as I know that 8pin male to 2 * 6+2 pin male comes with the R43SG. I bought mine from the original creator ( https://www.adt.link/product/R43SG-Shop.html ) thanks to way better pricing. Will receive it according to DHL in 2-3 days, I could tell more. I will use it with GTX 1660 Ti.
NOOOJASON liked
NOOOJASON
(@nooojason)
Sweet, let me know if it comes with the cable!
Good luck to your build!
EDIT -
I found out where to get the cable from this post:
https://egpu.io/forums/builds/clevo-n141zu-gtx-1060-6gb-strix32gbps-m2-adt-r3g-win10-timginter/
It looks really good, and if your order doesn’t come with one, you can get the one in the linked post.
Credits go to timginter for the name of the cable!
WIP eGPU:
Y700-15ISK
ADT R43SG
Dell DA-2
Gergo
(@gergo)
Yes the cable (the one you see on the thread) included. I have to say based on my build, you can't go wrong with the R43SG, plug in and play. No problems, no additional software nothing. Really glad with it.
NOOOJASON liked
NOOOJASON
(@nooojason)
Great!
Did you buy the R43SG from Aliexpress or the ADT-Link website?
WIP eGPU:
Y700-15ISK
ADT R43SG
Dell DA-2
Gergo
(@gergo)
From Adt.link website. Much better pricing, $48 USD + $30 USD DHL express shipping, so $78 USD all together and received it in 5 days.
NOOOJASON liked
NOOOJASON
(@nooojason)
I think I’ll do the same then.
Thanks! 🙂
WIP eGPU:
Y700-15ISK
ADT R43SG
Dell DA-2
FHQ
 FHQ
(@fhq)
It comes with a cable for 8-pin & 6/8-pin (2 pins detachable).
Lenovo ThinkPad X220 w/ Exp GDC 8.5c via ExpressCard & M.2
Lenovo Y700-17ISK w/ ADT-Link R43SG-TU via NVMe (More Info)
EVGA GeForce GTX 970 SSC ACX 2.0+ (Part # 04G-P4-3975-KR)
PSU: Dell DA-2 D220P-01 (18A), Tyco CAD240121 (20A)
2015 17" Lenovo Ideapad Y700 (GTX960M) [6th,4C,H] + GTX 970 @ 32Gbps-M2 (ADT-Link R43SG) + Win10 [build link]
