[Solved] where do i get the parts?
Page 1 / 2
computer newb
(@computer-newb)
hey guys, please excuse my ignorance as i dont know much about GPUs... my friend is sending me a NVIDIA  geforce gtx 1030  and i want to install it on an HP15-f272wm but dont know what i need to get other than the GPU... let alone where... any help is gladly taken into consideration
Reply
jefniro
(@jefniro)
Hi, from what I see your laptop hasn't any thunderbolt ports..only USB 3.0 that for latency problems (and bandwidth) it doesn't worth for a eGPU investment!
Reply
computer newb
(@computer-newb)
@jefniro it does have a internal wireless card and i happen to have a spare usb wifi card....
Reply
sabrefv
(@sabrefv)
The GTX 1050 is sort of considered entry level for modern games. The Gt 1030 is considerably worse (less than half the price performance index). If you went through the effort and expenditure to connect it to your laptop (which is very limited in how to connect an eGPU to your laptop anyway) you would not get anything more than low gaming performance so may not be worth the effort. To get an idea you would probably need to remove the bottom of your laptop, remove the Wifi card and plug a cable into that port PCI-MCIE (Very awkward see youtube videos on the subject search exp gdc egpu).
Reply
computer newb
(@computer-newb)
would something like a gpu dock work?
sabre how much is a gtx 1050?
Reply
Page 1 / 2
