Hey, i recently bought a exp gdc beast with express card, dell da-2 PSU and GTX660 GPU, what i missing is 6pin to 6pin wire. I'm i have several spear 4, 8 pin connectors and planning to just to make it myself. Should the connector wiring be exactly the same as the other end?:
Lenovo Thinkpad T430
GTX 660
EXP GDC Beast
64Gbps PCIe 4.0 x4 over 80Gbps Intel Thunderbolt 5 / USB4v2 ETA starting 2024 • eGPU Bandwidth Reference • eGPU Setup 1.35
2018 15" HP ZBook Studio G5 (Q P1000) [8th,6C,E] + RX 6700 XT @ 32Gbps-M.2x4 (ADT-Link R43SG) + Win10 22H2 // compares M.2 NVMe vs TB3 & RX 6700 XT vs RTX 3070 eGPU, 2.06kg triple-M.2 NVMe slot budget Workstation [info]
2018 14" HP EliteBook 840 G5 [8th,4C,U] + RX 6700 XT @ 32Gbps-M.2x4 (ADT-Link R43SG) + Win10 22H2 // compares M.2 NVMe vs TB3 & RX 6700 XT vs RTX 3070 eGPU, 1.48kg dual-M.2 slot budget UltraBook [info]
2015 15" Dell Precision 7510 (Q M1000M) [6th,4C,H] + GTX 1080 Ti @ 32Gbps-M.2x4 (ADT-Link R43SG) + Win10 1803 // compares M.2 NVMe vs TB3 eGPU performance inc unoptimized H-CPU BIOS [build link]
Hey,
I have a similar issue but with a 8 pin dell da-2 psu. I want to connect the dell psu and the side of beast 9.0b m.2 but the pins do not match.
I ve written more about the issue in this thread :
https://egpu.io/forums/expresscard-mpcie-m-2-adapters/unable-to-connect-dell-power-supply-and-beast-9-0b/#post-58661
Rok
