I am designing a box for the UT3G Dock I have, but I want to put the Usb output on the front panel of the box, I am attaching a sample picture, can anyone recommend a sample cable for usb4, I do not want to have problems with data transfer.
.certified USB-C "extension" cables (with 1 male and 1 female end) do not exist by design as it would make transfer/PD negotiation impossible under the current protocol. If you manage to get some uncertified on some Chinese market, it is likely to damage the hardware that you will connect it to.
Debian eGPU wiki | Debian ntsync howto | My failed AMD CPU + Nvidia eGPU + Linux build
2022 14" Dell Latitude 7430 [12th,10C,U] + RTX 3090 @ 32Gbps-TB4 (ADT-Link UT4G) + Linux Debian trixie [build link]
