Q: What do the eGPU port acronyms like 32Gbps-TB3 mean and what are their ranked & measured peak H2D/write bandwidths?
2018 15" Razer Blade 15 Advanced (GTX1070) [8th,6C,H] + RTX 3090 @ 32Gbps-TB3 (Mantiz Venus) + Win10 21H2
sdarmawan
(@sdarmawan)
Razer Blade 15 Advanced 2018
CPU Intel i7-8750H @2.20 GHz
Intel UHD Graphics 630 + GTX 1070 Max-Q
32 GB RAM, 1TB NVME
Windows 10 21H2
Mantiz Venus (custom mirror-polished surface)
RTX 3090 Dell OEM (taken from Alienware PC)
Hardware pictures
  • Install Windows
  • Install laptop drivers from Razer (including Thunderbolt 3 driver)
  • Run Windows Update
  • Connect eGPU to laptop
  • Install latest Nvidia driver
  • Open Device Manager to check if RTX 3090 is detected correctly
  • Done
I'm using this setup mainly for training deep learning models and occasional flight simulator game. So far everything runs smoothly.
One good thing about RTX 3090 Dell OEM is its length dimension only +/- 26 cm. It can fit my eGPU really well.
2018 15" Razer Blade 15 Advanced (GTX1070) [8th,6C,H] + RTX 3090 @ 32Gbps-TB3 (Mantiz Venus) + Win10 21H2 [build link]
nando4 liked
@sdarmawan, Thank you for sharing this build. Really cool touch with that polished mirror side panel!
2017 21" iMac 4K (RP555) [7th,4C] + RX 6800 @ 32Gbps-TB3 (Netstor HL23T-Plus) + macOS 13 & Win11 22H2 [build link]
sdarmawan
(@sdarmawan)
@itsage, thanks. It took forever for me to finish it by hand sanding 🙂
sdarmawan
(@sdarmawan)
It's been more than 2 years since I wrote this post, and I think I should update this again so others with similar situation may learn something from my experience.
So, few months after I made this post, Windows 10 pushed major update, that was when everything fell apart. My system crashed with blue screen easily every time I run my eGPU.  I tried to follow few tutorials on this forum related with BSOD issue, but nothing worked for me.
I've should write more details about things I have tried to fix, but I don't have time to do it so this my summaries:
  • The problem is because my laptop's internal NVIDIA GPU GTX1070 clashed with other NVIDIA card on external GPU. Once I tried using AMD card on my eGPU, no problem at all!
  • I tried to turn off internal GPU, no success in this particular notebook type
  • Last year I tried to fresh install & configure my system with Win 11 and follow through again BSOD tutorial from this forum, no success.
  • Now I'm happy enough to use free cloud GPU on Google Colab and Kaggle.
Best regards
This post was modified 2 months ago
